LT1/LT4 Tech 1993-1997
coolant light problem
Old Jan 29, 2005 | 10:54 PM
black96zz's Avatar
Default coolant light problem
My coolant light on my 96 z28 keeps coming on, yet my coolant level is filled to the top and the dealership says that everything is ok. Is this a common problem? Is it an electrical problem?
Old Feb 2, 2005 | 08:27 AM
elevensecond1967's Avatar
Default RE: coolant light problem
They have trouble with the low level coolant sensor. This is located on the side of the radiator about two to three inches down. They and not expensive and it would be a good place to start, unless it is an electrical problem. I think it is only two wires, that would make it easy to troubleshoot.
Old Feb 5, 2005 | 05:25 PM
JDman's Avatar
I had the same problem with my 94', the sensor is cheap and easy to change. You can get at the dealer.
g'luck
Old Feb 7, 2005 | 05:18 AM
black96zz's Avatar
Thanks guys
Old Mar 13, 2005 | 03:03 PM
tjrex65's Avatar
My 96 z28 does the exact same thing. I beleive it has something to do with the sensor in the overflow. My mechanic was able to get it to go away for a couple of days,but it alwas comes back.
Old Mar 14, 2005 | 02:16 PM
I don't think they have a sensor in the overflow tank. You can get the one in the Radiator at about any parts store. Simple enough that you can do it yourself and save some money.
Old Apr 7, 2005 | 01:39 PM
Blondy97's Avatar
Had the same problem, changed sensor. So far so good.
xXChipXx
Oct 25, 2010 01:05 PM
evilbeef54
Jul 27, 2008 09:47 PM
stud1502
Sep 17, 2007 04:54 PM
Saint_Ali
Dec 15, 2006 08:54 PM
Z28man
Oct 6, 2006 09:41 PM
