LT1/LT4 Tech 1993-1997
coolant level and electrical problems
Old Aug 29, 2006 | 01:18 AM
user 7208220's Avatar
Banned
Default coolant level and electrical problems
ok my gauges indicate that i need coolant. I dont though, i checked it and refilled to the top. why is the light still indicating that i need more coolant? i ran it through and everything. thats one problem...
the next is, sometimes when i am driving my radio just randomly shuts off, when this happens my windows will not go down either, but everything else works. After a minute of no radio, it will come back on and everything works fine...this has been on and off for the past 2 weeks. anyone know whats up?
Old Aug 29, 2006 | 04:21 AM
Saint_Ali's Avatar
Default RE: coolant level and electrical problems
you might need a new coolant sensor, check the fuses
Old Aug 29, 2006 | 09:51 AM
t4nk's Avatar
A fuse will not make the radio go off and then back on.. If something loses power due to a fuse.. It ain't comin back til you replace the fuse.
As far as the coolant light, disconnect your battery for 5 mins, let the computer reset... Post results..
Old Aug 29, 2006 | 02:45 PM
Low coolant lite when there is enough coolant can be caused by a gunked up or bad coolant level sensor, or by an open circuit on the coolant sensor leads. Unplug the wires from the sensor & short them together and the lite should go off, if it does not you have a wiring problem. If the lite goes off, you have a sensor problem. In this case try removing and cleaning the sensor, if it still does't work, replace it.
As for the radio and power windows, both of these items are connect to the Retained Power Module. It could be an intermittent connection to the module or the module itself going bad.
Old Aug 29, 2006 | 03:42 PM
Banned
that module thing sounds expensive...are they? and are they hard to replace?
Old Aug 29, 2006 | 07:07 PM
Not hard to replace but probably expensive. I would check all wiring and connection before changing out the module. All the module does is to provide power to the windows & radio for about 10 minutes after the engine is turned off.
Dana
Oct 29, 2012 07:52 AM
Chrisd0729
Sep 4, 2011 10:07 AM
evilbeef54
Jul 27, 2008 09:47 PM
aleksandr
Mar 25, 2008 01:50 PM
stud1502
Oct 19, 2007 01:19 AM
