LT1/LT4 Tech 1993-1997
Converting LT1 Z28 to Electric motor?
Old Feb 16, 2010 | 09:29 PM
CraZ28's Avatar
Banned
Default Converting LT1 Z28 to Electric motor?
Does anyone have any info on electric motors for cars. Since I can't get gasoline any more the only option I have is running electric motor. Seems to be an easy swap, using flywheels/trans bellhousing bolt pattern to hook up to the trans and viola. You can probably produce more horsepower off of DC power too!
Old Feb 16, 2010 | 09:38 PM
Boosted8vfury's Avatar
I dont like my title
are you serious?
Old Feb 16, 2010 | 09:45 PM
And what do you plan to use for electricity?
Old Feb 16, 2010 | 10:15 PM
CraZ28's Avatar
Banned
Ummm Batteries! Run a couple in series with storage capacitors just like I did with my stereo back in the day. I should be able to gut my block and fit an electric motor in it, welding the chopped cranks rear on the unit, then using the stock flywheel and bolting it up to the bellhousing. Viola, a six speed electric car.
Old Feb 16, 2010 | 10:17 PM
CraZ28's Avatar
Banned
Its in the works right now. I just need to find out about throttle control and how many batteries to run in series to produce around four hundered horsepower. Should be a simple swap!
Old Feb 16, 2010 | 10:22 PM
CraZ28's Avatar
Banned
I have been waiting for a crank for a month and then they sent the wrong one so I say screw it I'm going electric.
Old Feb 17, 2010 | 03:32 PM
you wanna do an electric swap?lotus has one and it is quick up to like 120 but it will only stay charged for like 3hrs then you have to charge it for 12hrs its pointless.
Old Feb 17, 2010 | 03:35 PM
CraZ28's Avatar
Banned
Na, I am going to let my Z-28 rust into a pile of iron and maybe smash it with some heavy equipment and then go buy a Nissan Leaf!
Old Feb 17, 2010 | 03:40 PM
whammer3024's Avatar
ROTM Winner
wow...i didn't even see this thread...i'm now, more convinced than ever, that you're a pure troll
Old Feb 17, 2010 | 04:02 PM
imalixZ28's Avatar
lmao .
Im gonna build a supercharged electric lawnmower, 750hp, 0-AWESOME in about 2.4 seconds
