LT1/LT4 Tech 1993-1997
Computer problem?
Old Nov 18, 2007 | 12:14 PM
97SuperSport's Avatar
Default Computer problem?
I have a 1997 Camaro SS. The other day when I went to go start my car it wouldn't start at all. The battery was fully charged tho, but my security light on my dash wouldn't go off. Once it did, it started right up. Also another problem that started last night, my head lights will shut off then go right back on while driving. The air bag and battery lights come on and go off as well when the problem with the lights happens. Any advice in this matter would be very helpful, thanks!
Old Nov 18, 2007 | 06:27 PM
Default RE: Computer problem?
You may have an intermittentshort circuit in the lights circuits. The headlights are protected by circuit breakers instead of fuses. This is a safety item to give you some lights (off & on) instead of going completely dark and staying there. Not being there I can only guess, but it would appears that when the short takes place it overloads the electrical system, and brings down the battery voltage causing the warning lights to go on. Or you may have a battery that has bad connections or just plain going bad.
Old Nov 19, 2007 | 01:34 PM
Thanks alot. Come to find out that the connections on my battery were so loose that it wasn't even funny. And I just put in a battery 3 months ago and tightened them myself. But thanks
KcLive
Jan 10, 2013 06:54 AM
Supermonkey147
Jun 15, 2009 12:31 AM
kwest
Jun 30, 2006 10:34 PM
92CAMARO
Mar 17, 2006 07:31 PM
