LT1/LT4 Tech 1993-1997
code confusion???
Old May 11, 2009 | 07:11 PM
Pecker's Avatar
Default code confusion???
alright where should i start, in january i had to replace my ecu, distributor, and ignition coil. last week my ses light came on, i got the codes and they were 16 and 26, i went to one place and the told me i had to replace all the same stuff i did in january, so i went some where else for a second opinion and they told me it was a crank or cam sensor issue. could someone give me some a little help here.
Old May 11, 2009 | 07:16 PM
95slvrZ28's Avatar
Code 16 (low-res pulse not detected) is in the Opti, so you may need to replace the opti. Code 26 is an EVAP purge solenoid malfunction, the two codes don't appear to be related.
Old May 11, 2009 | 10:37 PM
Pecker's Avatar
alright good to know, its seems to drive just fine just doesnt have all the power it should, can i keep driving it or will it do damage if i do
Old May 11, 2009 | 11:21 PM
what kind of distribitor did u get in jan?
Old May 12, 2009 | 10:04 AM
Pecker's Avatar
im pretty sure it was a remanufactured one
Old May 12, 2009 | 09:07 PM
95slvrZ28's Avatar
That could be why you're having issues. Get a new MSD or ACDelco OEM unit.
Old May 13, 2009 | 10:29 AM
^ slvr is right u probly got a bad unit. have not read to many good things about the rebuilt optis. have read its a good idea to seal the opti with some high temp rvt, gold or blue.
Old May 13, 2009 | 08:22 PM
Pecker's Avatar
ok thats what i needed to know, will it do any damage to the car if i keep driving the car till i get it fixed?
Old May 13, 2009 | 08:42 PM
shouldnt. at worst it will quit.
MusicMan
Apr 20, 2008 02:08 AM
Camaro Man 1999
Mar 17, 2008 05:09 PM
350rs
Dec 15, 2007 11:51 PM
Kblerelfs
Jul 3, 2007 09:59 AM
mongo
Feb 17, 2007 03:01 AM
