LT1/LT4 Tech 1993-1997
Code 43 ESC failure
Old Oct 22, 2009 | 04:08 PM
rwing7486's Avatar
Default Code 43 ESC failure
just got my 94 lt1 running aagain. But every now and then i get a code 43 pop up. and after driving around for a few mins the ses light will turn off. any ideas??? bad o2?
Old Oct 22, 2009 | 04:59 PM
DTC 43 has nothing to do with the O2. It is due to a bad knock sensor circuit. Could be the KS itself is bad, the KS loose or not gronded properly to the block (Do not use any tape on threads), wire from KS to PCM open or shorted to ground, bad KS module in PCM.
With key ON and wire disconnected from KS you shold see 5 Volt to ground and end of wire. From sensor to ground (wire disconnected) you shold measure 3300 to 4500 OHM.
JGuy07
Oct 26, 2012 08:53 AM
Jburd964
Feb 7, 2010 07:30 AM
clay7780
Sep 8, 2008 06:11 PM
kWil
82-92 V8 Tech
Dec 8, 2007 10:42 AM
randscr
Sep 8, 2006 10:48 AM
