LT1/LT4 Tech 1993-1997
cap and rotor failure on my girlfriend (1993 Z28) ?
Old Feb 14, 2010 | 10:41 AM
antonio85's Avatar
Default cap and rotor failure on my girlfriend (1993 Z28) ?
has anybody heard before of a distrebutor jerking in and out and destroying the cap and rotor??????? the mechanic that had replace the cap and rotor kit on my camaro a week a go (note cap and rotor kit was 299.99??? does that sound right?) said yesterday not when he was replacing it! that the distrebutor is a high preformance dis. and that could be the reason my cap and rotor is failing again? and then he goes on saying that my distrebutor could be jerking in and out and making the rotor rub onto the cap. does this make any sence?! before i had took it back to him i had two diffrent mechanics look at it and had them run a diagnostic on the car and both of them told me the samething there is something wrong with the cap and rotor!!
Old Feb 14, 2010 | 11:15 AM
Time Hybrid's Avatar
Cap and Rotor is a very common Failure on LT's, very hard to replace cause of the space, and very expensive. It just wear faster that other cap & Rotor system imo. Anyway, destroying it, might have to do with some thing really wear out at the shaft of the optispark distributor, that is making it rub hard against the cap. I had mine fail due to "water and who knows what" because of its OEM location, and I change it for a new piece from MSD. Sold the car, 20,000 miles on the actual owner, and no Problems so far.
Had an issue like this in a TBI 350 GEN I , CAP cracking, and kept replacing CA and Rotors for like 4 weeks, until I changed to a new Distributor.
Hope this helps.
Old Feb 14, 2010 | 01:47 PM
i would not recomend changing just the cap and rotor on these cars and would also recomend that the water pump be changed when the distributor is. an old pump can leak on the dist and ruin a new one in no time at all. it could be the cap was not installed right and that was the cause or it could be the shaft is lose and it alowed the rotor to hit the cap. i would look at the old unit and see. make the machanic explain how it was that it could happen.
Old Feb 14, 2010 | 09:12 PM
antonio85's Avatar
thank you! will post again tomorrow after i talk to the mechanic he wants me to be there when he removes the cap and rotor thanks again!!
Old Feb 15, 2010 | 07:56 PM
ryguy425425's Avatar
It took me a bit to figure out the girlfriend thing
Old Feb 15, 2010 | 10:26 PM
antonio85's Avatar
when my car was diagnosed the first time it gave me these codes 24,55,36, and 28 the one in question is 36 distributor ignition system (faulty high resolution pulse or extra low resolution pulse detected) shbox.com how many things could it be!!! the mechanic checked the the cap,rotor and distributor and found no problem at the time. the mechanic had me stand by the him for the prosedure which found wierd. looking at the parts (cap,rotor,and distributor) they looked grand. so what else should i check??? please help i miss my girl
Old Feb 15, 2010 | 10:38 PM
read this
97z28camaro
Jan 24, 2012 07:38 PM
LadyLuck
Dec 6, 2010 08:59 PM
