LT1/LT4 Tech 1993-1997
camaro wont run long
Old 10-19-2007 | 06:41 PM
ryan88z's Avatar
Default camaro wont run long
Got a 95 z28. I can start the car fine , drive about 3 miles and the engine will shut off completely. the engine wont start untill the engine cools down for quite a while . thought it was a coil issue so replaced that. the engine turns over but wont start. is this onen of those optispark issues?
Old 10-19-2007 | 08:10 PM
Default RE: camaro wont run long
Does it have a spark while cranking?
Is the fuel presure good while cranking?
When it stops, does it sputter or just drops dead?
Old 10-19-2007 | 08:47 PM
ryan88z's Avatar
still have to check the fuel pressure and for spark. it doesnt sputter it just drops dead with no warning like you turned the key off
Old 10-19-2007 | 09:24 PM
Sounds like an ignition problem, but before getting a new Opti, I would change the ignition module. Lot cheaper and easier, and they can be affected by heat if not bolted tight against the engine and using dielectric grease to conduct heat better. You may also want to take a look at all the wiring and connectors between the Opti, coil, and ignition module, as they have a habit of corroding.
Old 10-20-2007 | 06:19 AM
ryan88z's Avatar
great thanks allot pete. appreciate all the help . will check it out today and let ya know how i make out
Old 10-21-2007 | 08:37 PM
ryan88z's Avatar
changes the ignition module tonight , let it run for about 1/2 hour and no problems so far. it only ran for 5 mins or so b4 so i think were good. thanks for your help pete.
classicsjunky
06-01-2012 12:24 PM
Goldduster360
10-21-2011 05:28 PM
Inked88
07-24-2011 11:24 PM
M1garand
09-25-2009 03:28 PM
Quick Reply: camaro wont run long
