Camaro Not Starting
I have a 94 Z28 Convertible, with a built 4l80e trans with mega shift electronic switch and 3rd stage B and M shift kit green racing clutches and 2500 stall,and installed 3.42 gears original were 2.73's, I installed long tube headers and y pipe, so in the process eleminated the EGR system and air pump, Car thru codes for the o2 sensors so I replaced both and got extentions, and some other codes like the CCP code and fan fault. I programmed them out with the cat tuner, now when i was driving around the car shut down and i costed to a stop So i checked the coil and made sure i had spark and checked to see if i had spark to the plugs witch i had there too, then let is sit for like 10 mins, then started it, it ran really rough then shut down. and wont start at all, SES light is not on, before all this happened, I drove 75 miles with no problems gauges read fine. need a lil help
