LT1/LT4 Tech 1993-1997
Camaro Bolt Specs
Old Jan 10, 2010 | 02:21 PM
GMDCAMARO's Avatar
Default Camaro Bolt Specs
The Z28 I purchased had the Tranny (Auto) stolen and they took all the Hardware with them.
My Trans arrived on Saturday, so this is my only 'Hold up.'
I've been to the Dealer and they don't stock anything? The Parts Tech couldn't find any information on the bolts either.
I have done a little searching but cannot find specific and accurate bolt dimensions.
Here's what I need to know:
- Bellhousing bolts specs
- Tranny Mount to To Trans " "
- Crossmember to Frame " "
Also any recommendations on repairs while the Trans is out? Rear Main?
Thanks Gents!!
Old Jan 10, 2010 | 11:55 PM
GMDCAMARO's Avatar
Bump?
Old Jan 11, 2010 | 12:10 AM
robmnrd's Avatar
I don't normally condone thread hijacking, but if I were you I'd go find a recent build thread where someone had to pull the tranny, and ask that person specifically. I think that'd be your best bet, since it's a relatively uncommon issue.
Sorry I couldn't be of more help, man. I know how you feel being held up by all of a handful of little things. >.<
Good Luck!
Old Jan 11, 2010 | 09:10 AM
JordanT's Avatar
I am just about to put my engine and tranny back in so I can check those bolts for you. I will not be heading out to go work on it until Wednesday though. But I could get them then and post back to you by Wednesday night. Sorry it will take a few days.
Old Jan 11, 2010 | 09:33 AM
do the rear main seal if u plan on dropping the pan. so u are replacing with another auto.
the bolts for my 93 are a 3/8-16x1.38 280m for the trans to block and part #is 9439918 and shows there are 4.
a hfh w/con wa, m10x1.5x30,22 thd, 10.9, 7112 for the mount to trans and part# is 22570841 and there are 2.
a hex hd w/conical wa, m10x1.5x35, mach,10.9, pz7112 and part # is 11515946 and shows 4 of em.
hope this helps i know some bolt threads changed in 96 so that may be an issue.
clyon
Oct 24, 2009 06:00 PM
z28pete
Apr 13, 2009 02:13 PM
z28pete
Dec 20, 2007 09:38 AM
z28pete
May 6, 2007 06:56 PM
sewerrat
Dec 24, 2005 01:01 AM
