cam issues
hi their i just put a cc304 in my 94 lt1 i took everying apart and put it back the same way. i put the dots on the timing chain gear and the sprocket for the crank alliengned like the book says. installed the opti spark the same position with the grooves in the shaft. i went to go start the car and it wont start like the timing is off. did i miss somthing? i was wonderin if the opti spark went bad since i moved it around or somethin the car has 106,000 on it. i only undid the 1357 wires from the opti. it pops and back fires any ideas
the opti is origanal had bunch of grease on it i cleaned it with a dry cloth i double checked my wiring on the opti i did have 5 and 7 mixed i switched them around and it trys to start but nothin 106,000 miles on the car
most likely your opti. here is something to look at. does not always show a bad opti as being bad but may confirm. 4th Gen LT1 F-body Tech Articles
