LT1/LT4 Tech 1993-1997
Brake warning lights
Old Dec 22, 2005 | 07:12 PM
KJK's Avatar
KJK
Default Brake warning lights
Background. Replaced all four-brake pads/shoes last week. Found a leaky wheel cylinder on the right rear, replaced and bled it. The next day after buying a length of clear hose and reviewing the Haynes manual I bled it again. ABS valve, rear brakes, but could not loosen the front bleeder valves.
I get a "low-trac" light, feel the pedal moving, and hear some clicking from the ABS valve area during semi hard braking. The light goes out after a few seconds. This will happen a few times then the "ABS INOP" light will come on to stay until I turn off the engine.
Any ideas?
Kevin
Old Dec 22, 2005 | 08:26 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Default RE: Brake warning lights
what year is this car?
Old Dec 22, 2005 | 11:26 PM
KJK's Avatar
KJK
1995, hope I didn't forget anything else.
Kevin
Old Dec 23, 2005 | 02:12 AM
You may have loosened the ABS sensor cables at the front wheels while you were doing the brake job. Check the connectors on the sensor cables, disconnect them clean them & put them back. If this doesn't fix the problem, you should get the car scanned & see what the exact complaint is, in order to save time & money. You will need an ABS scanner or a Tech2 tool, low priced scan tools do not do ABS.
Craig Yates
Aug 25, 2014 05:03 PM
oldschool72
Jan 2, 2014 11:52 AM
martz0r
Oct 25, 2013 06:05 PM
subbie racer
LS Series Tech
May 8, 2011 11:16 AM
NasteeZ
Sep 19, 2007 06:29 PM
