LT1/LT4 Tech 1993-1997
bolt on's?
Old Jan 3, 2007 | 05:02 AM
camaroguy97's Avatar
Default bolt on's?
can anyone help me out, i have a 97 Z28 . ijus dropeda set of BBK shorty headers, flowmaster exhaust, a trick flow inlet elbo and a SLP cold air intake. i juswanted to know if any could help me out with getting a little more horse power on a budget.
Old Jan 3, 2007 | 01:14 PM
Default RE: bolt on's?
You are just about done with bolt on stuff, may want to try an elactric water pump. Get the PCM tuned to account for the mods you done.
Old Jan 3, 2007 | 10:10 PM
95slvrZ28's Avatar
Other reletively cheap bolt ons...
New MAF housing
LT4 Knock module
160 Degree thermostat
The first two will get you some, and the last one is kinda questionable, it can theoretically get you some, but as Pete already said, only with a PCM tune.
Old Jan 4, 2007 | 12:31 AM
94Z28interceptor's Avatar
if its an automatic you have, a shift kit doesnt exactly make hp, but you will definately feel a difference in performance.. they usually dont run you over $100, so theyre worth it
Old Jan 5, 2007 | 01:41 AM
gotalcoholmanup's Avatar
i had flowmasters on my camaro and it robbed me about 20 HP on the dyno. try getting rid of that and welding on something like a dynomax bullet muffler after the Y- pipe and a turn down. thats what i did and it sounds great!
Old Jan 6, 2007 | 04:32 AM
95slvrZ28's Avatar
I did some more research tonight, and found out that the 160 thermo is pretty much useless. Here's an article about a vette with an LT1 that Vette magazine is doin', they dyno it after every part, so you can see how much you get per dollar. Check it out, it's given me some guidance to say the least.
http://www.vetteweb.com/tech/vemp_06...ngine_buildup/
timopajala
Feb 22, 2017 07:27 PM
MBlac649
Jun 17, 2013 05:51 PM
MS69 YENKO/4-SPEED
Jun 22, 2010 05:07 PM
bivens8314
Jan 10, 2009 04:09 PM
gozzy341
Nov 4, 2007 08:52 PM
