LT1/LT4 Tech 1993-1997
Backfire!!
Old Dec 18, 2008 | 06:21 PM
Skippysnax's Avatar
Default Backfire!!
why does my camaro backfire so much now that its cold? does it need to be tuned, or is it just cold and i shouldnt worry about it?[]
Old Dec 18, 2008 | 07:59 PM
Default RE: Backfire!!
Which kind of back fire? Real backfire, such as flames out of the intake, or popping out of the exhaust?
Old Dec 19, 2008 | 12:43 AM
Skippysnax's Avatar
popping out of the exhaust.
Old Dec 19, 2008 | 01:14 AM
95slvrZ28's Avatar
It's characteristic of LT1's to pop out the exhaust (note, this is very different from actual backfiring). It has to do with the ECU not being able to update the fuel mixture fast enough as the rpm's drop and thus you get a little bit of unburnt fuel in the exhaust that then ignites. Why does it do it more when it's colder *shrugs* maybe the colder exhaust pipes help the fuel condense, that I'm not entirely sure about. My car's exhaust is much sharper sounding when it's cold...it's fun enjoy it
Old Dec 19, 2008 | 03:54 PM
Skippysnax's Avatar
thanks man, that makes a lot of sense cuz it does it less and less as the car heats up.
Old Dec 19, 2008 | 04:33 PM
95slvrZ28's Avatar
Another thing I thought of after I posted that, is when you first start the car it isn't running in closed loop mode, meaning it's utilizing the MAP sensor and the preset fuel trims in the PCM. Typically these settings are extremely rich, and thus you'll have more unburnt fuel in the exhaust to ignite. After the car heats up and goes into closed loop mode the computer can calculate the mixture on a dynamic basis.
imalixZ28
Feb 3, 2010 02:59 PM
Gordon24Camaro
Mar 8, 2008 07:50 PM
luvmysccamaro
Nov 27, 2007 09:50 AM
94Camaromil
May 20, 2007 10:48 PM
Mr. Zero
Apr 19, 2007 01:36 AM
