LT1/LT4 Tech 1993-1997
any 4th gen camaro...subs
Old Aug 18, 2009 | 07:38 PM
ricer_killaZ28's Avatar
Default any 4th gen camaro...subs
any suggestions on where to put subs/ what size/ how many? Not exactly much room in the car so i was wondering if anyone figured out a good setup
Old Aug 18, 2009 | 08:42 PM
95greenz28's Avatar
What I had in my 94 was a box that sat in the deep trunk area...It fitted 2 12" subs, I'm sure you can find the box around. I had 2 MTX Thunder 8000 series subs in it with a Kenwood 1000 Watt amp and boy did it kick.
Old Aug 18, 2009 | 08:47 PM
my only problem with that is that i have t-tops and they go in the deep trunk area
Old Aug 18, 2009 | 08:52 PM
95greenz28's Avatar
Haha damn...thats why I got rid of mine...my 94 was a hardtop and my 95 is t-tops. I believe I saw on crutchfield.com that they had one that went behind the drivers side wheel well in the trunk and it either held a 12" or 10" Sub.
Old Aug 18, 2009 | 09:39 PM
black95z28's Avatar
that is what i had in my car like stated above. but it didnt sound good cause the box had to be built so small. what i have now is 2 rockford p1 10's in a moveable box. when the tops are on the car, i put it on the rack to hold the tops. but when they are in the trunk, i move the box to the shelf in the trunk right behind the rear seat. when it is in the t-top location, there is so much more airspace and the subs sound much better. but with the subs on the shelf, there isnt much air space because they are less than 3 inches away from the rear window. just make sure you find a way to keep the subs on the back shelf so they dont fall off and something pierce them.
Old Aug 18, 2009 | 11:26 PM
i really like that idea thanks
Old Aug 19, 2009 | 06:28 AM
rondavis's Avatar
you can have a box custom made to go in the cut out behind the rear wheel well on the drive side and you can put a 12 in there thats what im going to do
Old Aug 19, 2009 | 11:23 AM
^^^ thats what i have works good.
Old Aug 19, 2009 | 03:32 PM
ZAngler's Avatar
I built a custom box for my t-top Z that fits on the shelf behind the rear seat. It holds one Kicker solo barrick 10" L7 sub and it faces the back glass. Oh yea! It’s also hooked up to a 1000 watt kicker amp @ 1 ohm and that thing really rocks! I like it b/c it gives off an even bass threw out the whole car! Allot of pep ask if have 12"s! And the best thing is it only weighs 35lbs! Hope this gives you any ideas!
94' Z28 M6 W/ a few mods!?!?
Old Aug 19, 2009 | 05:28 PM
ha my friend wants to do ^^that^^ idea with 2 12"s
