Ajust rockers
Take a look at this link. There are a couple options.
http://shbox.com/1/4th_gen_tech2.html#adjust_valves
You need to make sure you don't have any lifters that have collapsed causing the noise.
not near as bad with the lt1 as with the old school 350. lt1 just sorta spits it out there instead of a steady stream. i tried using a shop rag over the ones not being adjusted and seemed to work ok, just had to keep an eye on it.
