LT1/LT4 Tech 1993-1997
Advice for lifter replacment?
Old Dec 2, 2013 | 02:05 PM
cant say for sure, depends on what it really is. if its a lifter it could collapse and mess something up anytime, or not. ive run a noisy lifter for years before, did finally end up with a flat cam. the truck was toast anyways just used it to haul pots. i dont think anyone wants to say yah go ahead and have you come back and say the engine has a bent pushrod or valve through a piston. be best to find location if at all posible, check everything you can think of, plugs all in tight, egr pipe is not leaking, something is not rattling on the exhaust,
Old Dec 3, 2013 | 05:21 AM
oldschool72's Avatar
Aight thanks, guess I know what I'm tearing into this weekend haha
Old Dec 4, 2013 | 07:51 PM
Would stock lifters be ok for an aftermarket cam or should I use something different?
Old Dec 4, 2013 | 09:07 PM
i like comp cams. gm performance work too. bigger cam means bigger valve springs too. i have some tpis lifters in the lt1 now but i see they dont have them anymore, they look to be slightly modified comp cams. they sell what they call premium factory lifters now,,, not sure what that means. are you going with some 1.6 roller rockers?
Old Dec 4, 2013 | 09:34 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Get some ls7 lifters, measure your pushrod length, and then order the right length push rod. Some people say they are direct replacement and have good luck and others have to order new pushrods
Old Dec 5, 2013 | 05:24 AM
Yeah craby I was planning on going with the 1.6 roller rockers, and socom do you know what length the pushrods are supposed to be for the ls7 lifters
Old Dec 5, 2013 | 08:41 AM
if you are going with roller 1.6 rockers you will have to measure for your push rods anyways. brb
Old Dec 5, 2013 | 08:46 AM
Old Dec 22, 2013 | 01:14 AM
So I know it's been a little since I posted but I figured I would update yall. Pretty much it just got too cold for me to be able to do any work on the car so I'm pretty much just gonna run her through the winter and then next summer I'm planning on doing a cam swap with lifters and new top end anyway but from the sound of my car I'm about 99% sure that is justa lifter making the noise.
typappy
Jun 8, 2010 09:49 PM
Dznuts
Apr 29, 2010 12:12 PM
Jr. Mechanic
Sep 12, 2009 11:27 PM
oakwood69
LS Series Tech
Feb 12, 2009 02:46 PM
B4C Camaro
Jan 27, 2007 08:08 PM
