LT1/LT4 Tech 1993-1997
97 Z28 Auto trans problems???
Old Apr 5, 2011 | 02:09 PM
97LT1's Avatar
Question 97 Z28 Auto trans problems???
Hi I have a 97 Z28 camaro.
I am having problems with the auto trans. Its been driving good then it was getting the hard 1st to 2nd shift, now it is slipping pretty bad.
I did some research but am unsure of what transmission I have. I Believe its the 4L60E being a 97 but I am unsure. possibly the 4L60. any help would be appreciated.
I am also throwing ses light P1870 Trans component slipping. What I have found out is that most likely the valve body needs to be replaced.
Any help would be greatly appreciated so I can get this car back up and running.
Old Apr 5, 2011 | 03:28 PM
MaVeN's Avatar
Hi. You have a 4l60e. 4l60 was only in the 93 year. Here's a link to common problems and
https://camaroforums.com/forum/93-02-general-41/4l60e-commomn-problems-solutions-46109/
Old Apr 5, 2011 | 03:56 PM
about half way down the page youll see 27x-ko42, there are a few that apply to the 1870 code. might give em a call and see what they would recomend.
4L60E Performance Transmissions from PATC
Old Apr 6, 2011 | 10:02 PM
97LT1's Avatar
I'm Looking into taking the valve body off and just replacing it with a remanufactured one with a warranty.
Does any one thing that would solve my problem? It comes with the wiring harness and all sensors / solenoids.
Its Roughly $150 for the complete valve body.
I think it would be cheaper this way than rebuilding mine and boreing in out to fix it.
Old Apr 7, 2011 | 08:00 AM
torque_is_good's Avatar
you can try that and hope for the best.
you'll find that sunshell, sprag and clutches are common failures. If the valve body fixes your problem then that's great but go in expecting the worst and hope for the best.
Old Apr 7, 2011 | 10:49 AM
97LT1's Avatar
Alright I appreciate the help and info.
olered
Nov 13, 2011 08:52 PM
VALHAR
Oct 12, 2010 12:57 PM
MaVeN
Aug 31, 2010 01:17 AM
toml14
Dec 28, 2006 12:33 AM
RGill
LS Series Tech
Sep 15, 2006 12:07 PM
