LT1/LT4 Tech 1993-1997
96 ZR28 STARTING ISSUES
Old Oct 18, 2008 | 07:09 PM
kellygirlrox's Avatar
Default 96 ZR28 STARTING ISSUES
I have a 1996 ZR28 with a LT1. I have had trouble with it since day1!!! It doesn't always wanna start. It's somewhere in the wiring though. The last time it acted up we fooled around with the wires going into coil and it started but the temp gage wouldn't work properly. Next time it did it and we got it started the fuel gage no longer worked right. This last time... the RPM and Speedometer are fouled up!! UGHHH!!!!!!!!!!!!
It's now not starting again and I'm lost on ideas. Please help asap. I have no ride until I fix this car.
Thanx!
Old Oct 18, 2008 | 10:46 PM
Saint_Ali's Avatar
Default RE: 96 ZR28 STARTING ISSUES
well im sure the first thing is a moderator is going to tell you not to use red and big font like that.i believe its a z28, not a zr28, maybe that was a typo.sounds like you have a bit of a wiring issue.bad wiring could make it hard to start, but it also could be a weak charging system(battery,alternator), bad starter, dieing optispark(distributor), could be the ignition control module.its just hard to say and wiring gets complicated, your best bet is to take it to a mechanic, electrician to get the wiring checked out, otherewise it makes it hard to say what the problem is.
Old Oct 19, 2008 | 01:16 AM
Thank you for the advice regarding the red font. Sorry I'm not familiar with the "p.c." in and out's of the site. As far as the rest of your input... It's not a Z28, it's a ZR28, a hard to find limited edition version. It was equiped with a LG package. Car has Corvette engine andsuspension plus many other upgrades. And I noted that I am already aware of it being a wiring issue. I took it to a mechanic/ electrician and he was just as lost as I am. Hopefully, someone can offer some helpful info.
Thank you again for the font advice nonetheless.
Old Oct 19, 2008 | 07:18 PM
02StanGT's Avatar
I cannot find anything that can tell me what a 'ZR28' is. LT1 came in the Camaro and Corvette. Nothing special about that. Some folks have had gauges acting funny when their alternator is dying. If it does notwork right, your battery will not charge, and it will be hard to start.
Old Oct 20, 2008 | 02:43 PM
Spartan66's Avatar
ZR28 is a package made by lgmotorsports.com.
Old Oct 20, 2008 | 07:41 PM
Saint_Ali's Avatar
yeah but its not a add on from the factory or dealership, so i guess you can call it what you want
my 93 is a z28/rs/ss/zr1/z06 camaro
Old Oct 20, 2008 | 07:43 PM
02StanGT's Avatar
Damn! Sounds pretty rare
Old Oct 20, 2008 | 08:19 PM
Saint_Ali's Avatar
it is! it even has a corvette engine in it
but seriously if a mechanic couldnt figure out the wiring problem, take it to an electrician, i dont see how we can really help on that online
Old Oct 21, 2008 | 12:59 AM
Nessy's Avatar
lol something in my head just says "here we go again"
Old Oct 21, 2008 | 09:00 AM
whammer3024's Avatar
ROTM Winner
sounds like you got some major wiring issues and like alih said, if we can't be there to look at it then we can't help much. are we sure its not a computer problem?
