96 z28 horsepower
i puting together a list of things to up my horsepower, i bleve stock is 295(corect me if im wrong) im just looking for easy things to do. i dont want to have to pull my motor out. so if you could so kindly add to my list or link me to places where i can buy good parts that i have listed(not that i cant find them but just to compair prices.)also if something on the list isnt a good idea let me know.(also please make sure all parts are 50 state legal)
what i can think of-
up grade to a 58mm throttle body
change my mass air flow cencor
TPI "power now" inlet
cold air intake.(allready have)
High Pressure Fuel Regulator
Air Mass Flow Housing
its actually stock with 285, I have a 96' Z as well, the list you have is a pretty good start. Definitely do exhaust; headers or cat-back, computer reprogrammer, upgrade the rear end gear. If its an automatic a stall kit would be a good upgrade, if its a stick put in a short throw shifter. Could always do a cam, but could be alot of work, I haven't been down that road yet. Either way good luck......
The stock throttle body is fine until you're making a good amount of HP, think of replacing it once you start going for internals, not just bolt ons. A new MAF will do nothing for you unless it has a larger diameter, so just get the housing and be done with it. The high pressure fuel regulator is useless unless you end up replacing injectors, in which case you better be pumping out some major ponies, again, think about it after you go internals. I agree with derrick, go with LT headers, a good matching Y pipe, good cat back(do this first if you have a limited budget).
