LT1/LT4 Tech 1993-1997
96 Z28 Coolant Leak
Old Oct 10, 2011 | 01:25 PM
mab6680's Avatar
i get that same noise but its the ac leaking on the exhaust
Old Oct 10, 2011 | 03:28 PM
androzer's Avatar
Well i found that the hose of the heater was loosen a little I pushed the screw
and that sound was the sound of water leaking on exhaust , and when i park the car in hill the water fall in floor instead of exhaust and i see it :-).
any way there is another leaking i found after i left the mechanic in my way back home
i found near radiator a new leakage i guess the hose that look freak that has 3 heads , so rare to find it, I costumed one in place selling machines part.
thx for all .
Old Oct 11, 2011 | 07:58 AM
androzer's Avatar
Its the hose located in the driver side to the radiator in the down Corner ( not that 3 heads)!
Old Oct 12, 2011 | 08:43 AM
androzer's Avatar
Now i need real help!
guys the radiator is consisted of plastic and metal
the plastic where hoses spoused attached, one of those places is cracked ( the plastic ) can i seal it with Epoxy ?
or any kind of glue! what parts do i need if to fix that leakage !
can u guys guide me to any place where this problem has been mentioned before?
thx.
Old Oct 12, 2011 | 08:53 AM
mloaks's Avatar
Is J-B Weld available in Syria? there is a plastic formula, I think...
I'd ask you how it was going there re the Spring, but dont wanna get u in trouble... b careful.
Old Oct 12, 2011 | 08:55 AM
might try a plastic welder.
Old Nov 15, 2011 | 09:09 PM
androzer's Avatar
Thank you guys for the help,
I changed the whole plastic side the radiator, I didnt find V8 side
I found V6 but its the same instead there is no hose at the bottom of it, the man grilled a hole and entered a metal hose he is used to it , its his job.
and the other side seemed to be changed from the former owner of caprice and they did the same operation at the top cus the water reservoir of caprice is in the other side. ( I guess)
Any way i changed the hoses of heaters and other hoses and I shacked on the water level after week i found the Radiator is full so i Added Preston anti rust and anti antiscalant since the lowest temperature is +2 in my country no need for green water (anti frizz) . thanks for help .
mccoyj91
Mar 10, 2010 08:35 PM
dkn920
Jun 11, 2009 12:08 AM
VTXed
Nov 25, 2006 12:04 AM
terelk
May 31, 2006 04:18 PM
akohnz
May 22, 2006 06:58 PM
