LT1/LT4 Tech 1993-1997
96 Z28 ABS/TC Issues
Old Dec 16, 2011 | 11:08 PM
WIspartan1026's Avatar
May 2013 ROTM
Default 96 Z28 ABS/TC Issues
So I'm finally home for Christmas break, so I want to get some work done on the car (especially since I probably won't have enough time in the month I'm home between graduation and moving into my apartment). One of the things that needs fixing is the ABS/Traction Control, which hasn't worked as long as I've owned the car). Yeah I know that I can get along fine without it (I have the last two summers), but if something on the car is supposed to work, I would rather have it work, you know?
So anyway, last time I had it somewhat looked into (which was about 2 years ago), the shop said they tried to scan the ABS module and they simply couldn't communicate with it, no matter how they tried. So do you think that I just need a new ABS module, and my ABS/TC will work? Or is there another issue?
Old Dec 17, 2011 | 09:50 PM
abs and tc are the two things that are hard if not imposible to find info on.
Old Dec 18, 2011 | 11:28 AM
May 2013 ROTM
that's what I was afraid of...
Old Dec 18, 2011 | 02:14 PM
Grandpaswagon's Avatar
You can either take it to a dealer and see if they can scan the system and give you an estimate, but that will cost you pretty good.
Or, you can go to a wrecking yard and see if you can find a module to get for cheap and see if it gets you working.
Old Dec 18, 2011 | 03:14 PM
greenmachine96's Avatar
^ I agree with this. If the module is not communicating with the rest of the system it could be faulty.
Old Dec 19, 2011 | 01:19 PM
May 2013 ROTM
yeah, the module was originally my thought too. As far as taking it to a dealer goes, the shop tried scanning the system and simply couldn't communicate with it, so I feel like a dealer probably wouldn't be any more successful. I'll have to see if I can find a module anywhere around here, but Z28s are pretty tough to find in junkyards around here.
Old Dec 19, 2011 | 02:01 PM
May 2013 ROTM
so I was checking on car-part.com, and my search came up with "Chassis Control Box" as the part description. Does that make sense? And is it the same thing for a base car as for a Z28?
Old Dec 19, 2011 | 08:05 PM
im thinking that would be a body control module.
Old Dec 20, 2011 | 08:09 AM
well i just googled "96 z/28 ABS module" And found it listed as ABS control module on a couple of parts sites. You could look at some pics to make sure its the same.
WIspartan1026
Jun 19, 2012 04:28 PM
mick.mcgirr
Jan 3, 2011 11:23 AM
camarophil22
Feb 18, 2010 09:42 PM
red star
Aug 21, 2009 01:46 PM
laxloser18
Apr 28, 2007 09:06 AM
