LT1/LT4 Tech 1993-1997
'94 z28 seems rich
Old Jul 18, 2009 | 02:28 PM
NetDevil89's Avatar
Default '94 z28 seems rich
Hello, I just bought this car about 2 weeks ago and to me, its running really rich.. blowing out a gray/bluish smoke when you give it gas.
Any opinions on this? I've ran a can of seafoam through the induction/oil and a full tank with B12.
Old Jul 18, 2009 | 06:32 PM
95slvrZ28's Avatar
Blue smoke is usually an indication of the car burning oil (probably pushing oil past the rings), not a rich mixture. Does the car smell rich or is it just the smoke?
Old Jul 18, 2009 | 06:40 PM
NetDevil89's Avatar
It smells pretty rich. When i get on it a puff of smoke comes out the back and when it revs down, the smoke is thicker. Kinda weird to me. My girlfriend just told me that she can't see a tint of blue in the smoke, just white/gray. I put my hands behind the exhaust tips and it just smells like gas :\ As much as I hate to say it.. I'm thinking it might be the valves seals. Whats that kind of repair bill look like?
Old Jul 18, 2009 | 07:32 PM
Valve seals do not make an engine run rich. Bad valve seals allow oil into the combustion chamber and cause smoke, especially when decelerating.
Old Jul 18, 2009 | 08:01 PM
NetDevil89's Avatar
How expensive of a fix is this?
Old Jul 19, 2009 | 05:01 PM
First of all you need to know what exactly is causing your problem, and then decide if you want to fix it. But, to answer your question, seals are cheap, and labor would be most of the cost. The gray white smoke is more of an indication of coolant entering the combustion chamber than oil burning. have a service shop test the coolant for presence of combustion gases.
Old Jul 20, 2009 | 09:59 PM
NetDevil89's Avatar
Could this be a bad piston ring?
Old Jul 21, 2009 | 12:39 PM
95slvrZ28's Avatar
First you need to determine whether the smoke is white/grey or blue, are you losing coolant? Are you losing oil?
Old Jul 21, 2009 | 10:33 PM
NetDevil89's Avatar
Not losing any coolant. As far as oil, I'll have to get back to ya on that. Just did an oil change yesterday.
thebandit110
70-81 V8 Tech
Mar 18, 2013 07:11 PM
atlanta2008
67-69 V8 Tech
Sep 13, 2007 06:24 AM
91_camaro
Oct 22, 2006 11:41 PM
79camaro355
Jul 5, 2006 09:31 PM
