LT1/LT4 Tech 1993-1997
94 z28 over heating only after it warms up
Old Jun 17, 2013 | 05:38 AM
shwacko's Avatar
Default 94 z28 over heating only after it warms up
I just swapped the motor out in my 94 z28 I got a 93 z28 donor car I switched intakes and all sensors off the old one,reused water pump off the old motor cause it was in better shape,havent replaced themostat as it was replaced in the old motor and just left it in when I swapped manifolds,the problem im having is it over heats when driving around town,on the highway it is fine,i need to know how to properly bleed my coolant system,thats what I think the problem is,and by the way ac has been removed and the fans have been put on a toggle,any help would be appreciated
Old Jun 17, 2013 | 07:28 AM
moved your thread to the lt1 tech section. the forum issues is for problems with the site. try bleading this way and see if it helps. also make sure your air dam is in place.
https://camaroforums.com/forum/lt1-l...-system-66742/
Old Jun 18, 2013 | 05:46 PM
Grandpaswagon's Avatar
+1 on the air dam being in place and in decent shape. It really helps to pull air across the radiator at slower speeds.
Old Jun 22, 2013 | 11:42 PM
shwacko's Avatar
yes air dam is in excellent shape,i have bleed the coolant system over the last few days and it is all good now thank you for your help everyone,sorry for not posting the thank you sooner been busy and also there is a four hour time diff
royco95
Dec 15, 2012 06:07 PM
LemansBlue
67-69 V8 Tech
Apr 7, 2011 06:19 AM
mrsdeano
Sep 23, 2010 10:35 AM
Derch
70-81 V8 Tech
Jul 22, 2010 12:41 PM
Robs_97
Feb 17, 2006 11:35 PM
