LT1/LT4 Tech 1993-1997
94 Z28 flooding out
Old Oct 2, 2011 | 02:31 PM
Sykotikal's Avatar
Default 94 Z28 flooding out
I have a 94 Z28 with the LT1 and T56. My car will run for about 20 mins before it seems to flood out and die. This issue happens whether its idling in the drive or running down the road. I tested my old cts after replacing it and had acceptable readings and 5.01 v across the plug. The wires from the cts to the ecm are solid and all 3 grounds for the ecm are good. Any one have and other thoughts?
Old Oct 2, 2011 | 06:27 PM
SS/Z28cam's Avatar
Your opti is going out had the same problem
Old Oct 2, 2011 | 06:52 PM
torque_is_good's Avatar
ALDL OBD1 OBD cable OBDI OBD2 engine codes
buy the cable
datalog the car
my money would be on O2 sensors
Old Oct 2, 2011 | 08:55 PM
Sykotikal's Avatar
thanks aldl cables did not have the one i need but i got one from akm for a lil more money...can you suggest a good free program to go with it?
Old Oct 8, 2011 | 09:58 AM
i have used datamaster
Old Oct 9, 2011 | 07:42 AM
Sykotikal's Avatar
thanks craby.....torgue no o2 codes and readings look good time to pull my opti and check it
Old Oct 20, 2011 | 04:05 PM
Sykotikal's Avatar
so after finally having time to pull my opti, i saw all my contacts were corroded. I cleaned all my contacts and my car stopped running hot and cutting off on me. It would seem the problem is solved...for now. Now time to budget in a new opti
bvans
Jan 6, 2010 10:14 AM
draggo144
Nov 24, 2008 09:29 AM
aaron89
Mar 25, 2008 03:36 PM
TheShadowCleric
82-92 V6 Tech
Aug 18, 2007 07:07 PM
BadAzzBowtie
Feb 28, 2006 01:16 AM
