93 z28 power windows?
Well only my passenger side window will roll up, and only with the drivers side control switch. The switches that do not work fill like they have no tension like the one that works. What does this mean, that the switches are broke? Has this happened to anybody else? Thanks.
you can get switches that fit pretty easy, 93 to 97 fit. ebabe or check these places
RMS Automotive Supply, LLC - Keeping your ride on the road!
GM Parts Direct: Your direct source for Genuine GM Parts
thing is the 93 is the only year to have yellow lettering and graphics on its switches and ***** so white is common and yellow almost impossible to find.
One way to find out is pull them put and see if the tabs are broke. I used a jewlers screw driver for a while until I gound some at a junkyard. Kinda scarce unless you find a v6 model cause most people pass those right up
PCweber
Jul 11, 2012 06:13 AM
