LT1/LT4 Tech 1993-1997
93 z28 EGR?
Old Oct 15, 2011 | 04:15 PM
chad kennith's Avatar
Default 93 z28 EGR?
How did you guys reach your EGR to take it off? Thanks.
Old Oct 15, 2011 | 04:17 PM
BasicConcepts's Avatar
Technical User
I went from the drivers side of the motor its 2 10mm nuts
Old Oct 15, 2011 | 09:20 PM
Catmaigne's Avatar
Either side works, just grab a box wrench.
Old Oct 16, 2011 | 08:29 AM
its tough but there should be enough room between the intake and the air pump line to get a wrench in there.
Old Oct 16, 2011 | 02:04 PM
Catmaigne's Avatar
Also, unplug the vacuum harness for the EGR so you don't damage it. It connects to the EGR, back of the solenoid, and the intake by the PCV valve (assuming it's the same for 94+).
