LT1/LT4 Tech 1993-1997
93 z-28 ABS sensor location
Old Apr 21, 2009 | 02:07 AM
greenarrow's Avatar
September 2009 ROTM
Ok, I know what you're talking about now. I've done about four front wheel hubs and I didn't really notice that the wire was different. It has the standard two prong connector that connects to the wheel hub. Every time I've had a hub go out it's thrown a SES light, not an ABS inop light. I don't know if other years would be different. My problem is a code 57, left front motor short to ground. But everytime I've had it checked out they haven't been able to find anything wrong. The ABS motor kit checks out fine, they can't find a short in the wiring, which is what I think it is but haven't dove into changing that yet. I had my wife take it to a big dealer in Miami while I was in Korea and they had it for a month and spent I don't how many hours and brought in a specialist from somewhere and they couldn't figure it out either. I don't know, sometimes it'll stay on the whole time it's started, other times it take a while before it comes on, and then sometimes it'll go off while driving. And that makes me think that it's def a wiring problem.
Old Apr 21, 2009 | 10:14 AM
west 93 z28's Avatar
I checked for codes again but couldn't connect. Anybody know where to get the abs sensors from
Old Apr 21, 2009 | 10:32 AM
the front ones are in the hubs so i pretty sure u have to buy the hubs to get the sensors for the front. most parts stores have em or can get them overnite.
Old Apr 21, 2009 | 12:53 PM
greenarrow's Avatar
September 2009 ROTM
Look at gmpartsdirect, you can get them cheaper other places, but one those I've never had a problem with the GM stuff.
Old Apr 22, 2009 | 01:35 AM
95slvrZ28's Avatar
GA: An intermittent light is usually indicative of a bad connection, this could be the connector itself (either the sensor side or the wire side), potentially a wire that's worn through or cracked insulation and is now shorting etc.
Old Apr 22, 2009 | 01:42 AM
greenarrow's Avatar
September 2009 ROTM
I know, I've been all over the wirering with no luck, the last dealer that had said they went over every wire and tested every wire and found no shorts, so at this point it's replace the wirering and hope that fixes it, but I got bigger fish to fry before that.
Old Apr 22, 2009 | 01:46 AM
lt4weeda's Avatar
Mine have been on in my car since i bought it, I just said screw it from the get go, if I ever want to make the abs inop go away in my dash ill just get rid of the bulb
Old Apr 22, 2009 | 07:33 PM
my car wont pass safty inspection and the light comes on after a few feet and stays on the hole time the car is on
Old Apr 22, 2009 | 08:08 PM
ok so far what have u done? what is your budget?
Old Apr 23, 2009 | 07:26 AM
  #20
the car is stock for now and i have checked the wires, change the abs motor,and the abs relay. but I can only find one abs sensor
