4L60E Question
Just got my 4L60E rebuilt in my 1994 Camaro with a 2400 rpm stall and shift kit.
When I nail the gas from about 50 mph, the transmission kicks down into a lower gear, and I'm getting some "tire chirpage." Is this normal with a higher stall and a shift kit, or is the transmission slipping or something, causing the "chirp?"
I guess everything seems to be ok, but I just want to make sure. Also, when I floor the gas, the transmission kicks down, the RPMs raise and the car starts to pull (obviously), but then when the transmission shifts up a gear, I get that "shove" in the back, and the car really takes off. Is it normal for the revs to come up, and then a few moments later the car takes off like a freight train?
ORIGINAL: z28pete
You have no problems, enjoy.
I kinda missed that part about the downshift. The transmisssion should grab immediately and not let the engine flare up on the downshift. May have a problem with 3-2 control solenoid. Also what fluid are u using?
ORIGINAL: z28pete
I don't wanna say that the transmission is slipping, because when I floor the gas, the transmission kicks down, the rear squats, and accelerates and pulls me to the seat, but it isn't until the transmission shifts back up that the car really "gets it."
It's very difficult to explain what's happening without someone riding in the car so they can experience exactly what I'm talking about.
ORIGINAL: wishmaster
Are you sure that when you kick it the tires aren't spinning causing the engine to rev,and then it hooks up and starts pulling. Because i have a 93' and at low speeds mine does that.
