LT1/LT4 Tech 1993-1997
373's
Old Jan 21, 2008 | 10:29 PM
kyleb's Avatar
Default 373's
where can i find these for my 95 z28? i seen these : http://cgi.ebay.com/ebaymotors/RING-...2em118Q2el1247
will these work?
also how much work is the install, any special tools needed? also would i need to reprogram anything?
i hear theres ahuge difrfrence in take off so im looking forward to getting some
thanks guys
kyle
Old Jan 22, 2008 | 06:57 PM
biohazard's Avatar
Default RE: 373's
Yes it is a very nice diffrence! ....but honestly I would order them out of summit or jegs or somewhere else before ebay?? Thats just me though! I have seen a lot of cheap made parts on ebay and you are going to want a good quality part.! Also unless you know how to put gears in a rear end I would take them to a shop cause I have been told its tricky?? I would not want to chance it! I have 4.10's in mine and I love it! The gears from summit along with everything else cost me around 400 i beleive.
Old Jan 22, 2008 | 06:59 PM
Big_Bird_1985's Avatar
Default RE: 373's
Yeah they will make a difference. Especially if you have an auto if its an M6 I would go bigger than that. All you will need to reprogram is the speedometer. An aftermarket tuner will do that for you. I would strongly suggest that you have the pros do the install for you. I did mine myself (big mistake) and I ended up having to get it rebuilt a month later.
Old Jan 22, 2008 | 07:51 PM
kyleb's Avatar
Default RE: 373's
aweome ty for the replys guys....i have a few more questions tho now..
i dont know if i have an mp6 or what but its a 1995 z28 auto w/shift kit so wha would i have if its not the mp6 wha i it and is he 373's cool for that.
also if somon can give me a place to look for these programers.. i herd of the pcmforless? is this what yer alking about? is it easy to program i and all?
and last q what kinda shop would do this kinda work? transmission shop?
thanks alot
Old Jan 25, 2008 | 11:13 PM
mycarsux88's Avatar
Default RE: 373's
the gear swap really isnt that hard. i helped my buddy put a 4 10 in his t/a just go slow and remember how it came out. it really isnt that hard.
Old Jan 27, 2008 | 12:59 AM
95slvrZ28's Avatar
Default RE: 373's
The hard part about rebuilding a rear-end isn't necessarliy getting everything in right, you can get a Haynes/Chiltons manual to help you do that. The hard part is getting the gears setup right so they don't hum or heat up a ton when you're driving.
