LT1/LT4 Tech 1993-1997
3.73'? Perks and Cons
Old Jun 5, 2011 | 05:52 AM
xXChipXx's Avatar
Default 3.73'? Perks and Cons
Id like to get 3.73's but I want to weigh the good and bad since its my dd. How much do you think it would effect gas mileage while driving casually? Also, given a little wheel spin, how well will the stock rear end hold up?
Old Jun 5, 2011 | 08:05 AM
stock rearend is rated to 350hp. thats not saying you can go out and do clutch drops with 315 tires all day without having an impact on the life of the unit. 323 to 373 i lost 5mpg.
Old Jun 5, 2011 | 04:03 PM
xXChipXx's Avatar
Did anyone else calculate how much mileage they lost, particularly with a set up similar to mine?
Old Jun 6, 2011 | 04:09 AM
xXChipXx's Avatar
Any suggestions on which set I should buy? Im probably only flirting with 300hp and im not going any further for a while so if there is a set that I can get buy that will be good enough for that, it would would be ok.
Old Jun 6, 2011 | 02:59 PM
je$$up97's Avatar
i lost about 5mpg's too. stock rear end is always the achilles heel of this generation. If you abuse it, it will be the first to go.
Old Jun 7, 2011 | 02:14 AM
xXChipXx's Avatar
Do you think a tune would make the mileage pretty minimal? I have the factory tune now.
Old Jun 11, 2011 | 08:48 AM
xXChipXx's Avatar
I decided I am going to have the gears installed at a shop, not worth the risk and there is local shop that is only going to charge me $200. But im not sure exactly what gear set I need or which install kit. Herronperformance only has one option, is that the right one? But it doesnt look like they sell install kits
luciora
May 19, 2010 03:05 AM
LesDrive
May 2, 2010 06:09 PM
Adam78
Dec 13, 2009 12:06 PM
Spartan66
Jul 4, 2007 10:11 AM
microkid
Feb 21, 2007 01:47 AM
