LT1/LT4 Tech 1993-1997
1997 Z-28 po400 egr code
Old Sep 9, 2008 | 05:54 AM
orrs's Avatar
Default 1997 Z-28 po400 egr code
I keep getting the po400 code, I have checked the vacuum hoses,cleaned & checked the egr valve and checked the egr valve solenoid. From the reading that I have done I have learned that if you don't have enough exhaust backpressure it can through this code.The car has the cats removed but I did that two years with no problem untill recently. Any ideas ?
Old Sep 10, 2008 | 10:18 PM
stonecoldtrk's Avatar
Default RE: 1997 Z-28 po400 egr code
do you have 02sims? maby one has gone bad
Old Sep 11, 2008 | 01:49 PM
orrs's Avatar
I do have O2 sims, I will check them and let you know thanks.
Old Sep 12, 2008 | 04:54 PM
tammy's Avatar
Banned
PluggeD EGR ports????
Old Sep 12, 2008 | 05:03 PM
02StanGT's Avatar
Whatdo the O2 sims have to do with anything?
Old Sep 12, 2008 | 10:14 PM
i dunno, just wonderin if one possibly went bad and is throwing a code.
Old Sep 13, 2008 | 12:01 PM
02StanGT's Avatar
He already knows what the code is.
Some good reading... http://bbs.zuwharrie.com/content?topic=27769.0
http://www.obd-codes.com/p0400
zackypoo
Jun 16, 2010 03:21 AM
maydanian
Nov 17, 2009 06:08 AM
bsmith01
67-69 V8 Tech
Apr 7, 2008 08:15 PM
matzss
Dec 5, 2007 01:17 PM
aliix
Jun 7, 2007 12:45 PM
