LT1/LT4 Tech 1993-1997
1996 5.7 LT1 overheating
Old Oct 30, 2011 | 03:15 PM
jtrotter's Avatar
Default 1996 5.7 LT1 overheating
I have just purchased a 1996 camaro ss 5.7 LT1 that is overheating and fans won't come on. I replaced sensors on driver side head and the other on water pump. I took off sensor on radiator and cleaned it. Replaced thermostat and changed antifreeze. Straight wired the fans and still running hot. Any ideas as to what try?
Old Oct 30, 2011 | 03:46 PM
numskull223's Avatar
Have ya tried bleeding the air out of the system?
Old Oct 30, 2011 | 04:17 PM
Catmaigne's Avatar
You need to properly bleed the system or the air pockets will cause your car to overheat. Jack up the front of the car when filling.
4th Gen LT1 F-body Tech Articles
For reference, fans kick on at 226 for low speed and 235 for high. Your car is not overheating unless it's reaching the red zone. These cars will yoyo between 210 and 230 in traffic.
Old Oct 30, 2011 | 04:39 PM
jtrotter's Avatar
ye thanks a million guys and gals if any responded thats what i have just finished doin , and running cool now, however cooling fans still not working, i am realy all new to this whole lt1 life , i am getting no power to the fans. and wire jumped the dlc ,5th & 6th terminals , may be in the ecm or brain
Old Oct 30, 2011 | 05:34 PM
jtrotter's Avatar
Car is running real good, looking good, but no fans. Ran straight wire and they work. No power on plugs. Would this be brain box? Already switched out relays, no change.
Old Oct 30, 2011 | 07:41 PM
The fans are set to come on between 220 to 230 degrees, just before the red mark on the temp gage. The computer reads the coolant temp sensor and activates the 3 fan relays as needed in order to get the proper fan speed. This engine is designed to run hot, and you may not be waiting long enough for the fans to come on. If you have AC, the fans should come on when you turn the AC on. If they do, then everything from the computer to the fans is good.
Old Oct 31, 2011 | 08:32 PM
jtrotter's Avatar
Cool
ye thanks for the help from everyone got the engine running cool and that's from the air bleed screws , still no fans and no ac cycling on or any signs of life there . So maybe my fan problem is related to the ac problem , going to check power there at the compressor tomorrow and see where I am at from there. Seems related.
Old Nov 7, 2011 | 02:33 PM
ColinH's Avatar
Any news on your fans working or not? I have the same problem with a 96 z28 and I just cant figure out what it is.
Old Nov 8, 2011 | 08:43 PM
jtrotter's Avatar
I haven't had time to diagnose the problem. If you're a/c isn't powering on you may have the same problem as i do. Ifyou have any luck with it let me know and I'll do the same.
Old Nov 8, 2011 | 11:00 PM
ColinH's Avatar
I might just change my PCM to see if that solves my problems. I pulled my coolant temp sensor and my fans work so I have eliminated the fan motors, relays and fuses from being the problem. I think the PCM's are just not giving the signal.
It's funny, we both buy 96 LT1's and have the same problem! hopefully one of us can figure something out.
I have also read and was told that when your a/c isnt charged then your fans wont turn on, even once your car is hot.
