LT1/LT4 Tech 1993-1997
1995 Camaro Z28 V8 LT1 Water pump leaks
Old Apr 4, 2011 | 10:47 AM
Jaar123's Avatar
Default 1995 Camaro Z28 V8 LT1 Water pump leaks
]Good morning to all:
I will appreciate advice how to repair leak on the water pump.
of my 1995 Camaro Z28 V8 LT1 with 7000 miles.
Thanks
Old Apr 9, 2011 | 08:30 AM
replace the water pump,,,, well i guess it depends on where its leaking from, if its a leaky gasket (leak from the sides) or a failing water pump (leaking from the center/weap hole) or leaking hose/s
i moved your thread to the lt1 section. read directions for the site please. thank you, welcome to and enjoy the site.
Old Apr 9, 2011 | 09:24 AM
je$$up97's Avatar
how old is the pump? More than likely you'll want to replace the whole unit and gaskets. It's also a good time to check all the upper and lower hoses for cracks and leaks. for most novices, its about a 2-3 hour job. Invest in a haynes manual and it will walk you through it.
Old Apr 9, 2011 | 10:54 AM
BasicConcepts's Avatar
Technical User
you might want to replace the opti too you prob dripped some coolant in there
Old Apr 10, 2011 | 06:28 AM
Jaar123's Avatar
Good morning to Craby, Je$up97, BasicConcept and Dark Knight:
Thanks for your advice.
The water pump leaked through the center.
We could not get a new one and decided to fix the pump taking it to a specialty pump store and replace all the gaskets and check all the hoses.
Any more advices?
Best regards.
Old Apr 10, 2011 | 11:31 AM
Jaar123's Avatar
Good morning BasicConcept:
What is " opti "?
Where is located?
How do you replace it?
Do you know the # and price of the item?
THANKS.
Old Apr 10, 2011 | 11:38 AM
opti is your distributor and is under the water pump. can pick one up thats warrented/acceptable from chandlermotorsports who is a site sponsor.
Originally Posted by craby
one of our sponsors chandlermotorsports sells a opti for less than 200 bucks with a warrenty. would that help.
https://camaroforums.com/forum/vendo...-praise-54550/
http://chandlermotorsports.com/11040...optispark.html
Old Apr 10, 2011 | 11:48 AM
the seals are what goes on these water pumps. when they go the antifreeze will drip down on the opti and can ruin it. rebuilt pumps can fail at startup or soon thereafter, keeping in mind a failing pump can ruin the opti,,, if your opti is good then i would not mess with it with a rebuilt water pump on there. be a bummer if you bought a new opti and the pump failed and ruined it. should be able to pick up a new pump at any parts store, may have to order it for you. admittedly the pump is not cheap but neither is a opti.
Any more advices?
Best regards.
Old Apr 12, 2011 | 01:35 PM
ChandlerMotorsports's Avatar
Former Sponsor
It's not a mandatory replacement but take a look at the unit. If its discolored in the middle you might want to be mindful of any changes in driving behavior. A couple drips isn't going to nuke the unit, but if you continue to drive after its leaking eventually you'll pay the price.
Old Apr 13, 2011 | 12:18 PM
Jaar123's Avatar
Good morning ChandlerMotorsports:
Thank you for your advice.
The opti is fine.
Since we could not get a new water pump, we replace the center pin and all the gaskets. So far it is working. Eventually we will order a new pump. The Camaro Z28 has 7000 original miles. We drive it twice a week only.
Best wishes.
