LT1/LT4 Tech 1993-1997
1994 LT1 into 1996 Z28
Old Dec 28, 2011 | 10:43 AM
cdnturboz's Avatar
Thanks for the info, I have also just found a 94 firebird lt1 that I may try to get. What is involed with installing a crank sensor?
Old Dec 28, 2011 | 03:46 PM
you need to have the front cover with the place to put the crank sensor. then its easy. http://shbox.com/1/engine_front_diagram.jpg
Old Dec 28, 2011 | 04:10 PM
In addition to the timing cover, you need the reluctor, the 96-up crank hub, and keyway.
Old Dec 28, 2011 | 04:33 PM
i never noticed the balancers are different on the 96 97
Old Dec 29, 2011 | 11:17 AM
cdnturboz's Avatar
Found another 95 lt1, I'm assuming its similar to using a 94 lt1?
Old Dec 29, 2011 | 11:53 AM
Yes it would. On the plus side, that one would have the new style (vented) opti, so you wouldn't have to change the cam.
seebs01
Dec 22, 2014 11:54 AM
jseal-57
Apr 17, 2012 07:47 AM
Norse1974
Jan 11, 2010 05:40 PM
dustinb
Jun 29, 2007 09:08 PM
soulonfire11
Jan 14, 2007 02:13 PM
