LT1/LT4 Tech 1993-1997
1993 z28 lt1 timing.
Old May 12, 2008 | 03:00 PM
travis t's Avatar
Default 1993 z28 lt1 timing.
can anyone tell me in the timing can be set manually?, and if so how..thanks..
Old May 13, 2008 | 05:55 PM
Mr TQ's Avatar
Default RE: 1993 z28 lt1 timing.
The base timing is preset when the engine is manufactured, no adjustment is possible. Timing advance and retard are accomplished through the ECM.
Old May 13, 2008 | 05:58 PM
SpecterGT260's Avatar
Ninja Administrator
good answer.
some motors that are PCM controlled still may be manually adjusted, the 4.6 mustang for example. i am not aware of anything like this for the chevy side.
Old May 26, 2008 | 12:00 AM
Mustangfighter96Z28's Avatar
no you can't, the way the opti spark is set up it sets the time. if you go to napas website and read up on the opti it'll tell you all you need to know. its actually kinda genious what they did with it, too bad its such a pain in the *** sometimes like when you have to replace it when a coolant line bursts like mine, lol.
Old Jun 5, 2008 | 04:42 PM
LT1RUNNER's Avatar
The LT1 is timed through the pcm. Only MSD offers a opti that can be adjusted for timing but it's a waste of money because the pcm will re-adjust the timeing.
MPatterson
Dec 11, 2013 09:09 PM
larco
Jun 16, 2012 10:11 PM
ScottD
Mar 18, 2010 12:36 AM
JZ0488
Aug 1, 2005 02:07 PM
