LT1/LT4 Tech 1993-1997
1993 Camaro Z28 engine diagnosis
Old Jun 15, 2014 | 04:12 PM
yep ignition coil/control module or coil can fail after warming up. I'm sure the opti can as well although i dont recall reading about it happening. i had a icm go and it would die while going down the road then it wouldn't start for 10 or 20 minutes. starter can also lose torque after heating up causing drag but then the starter will engage it just won't turn the motor over fast enough or will engage but not do anything. I'm sure there are several other things that can cause what your seeing. flash it and see if you have anything show up. its easy and doesnt take much to do.
Old Jun 15, 2014 | 11:07 PM
superandy411's Avatar
I think he was referring to hyrdo-lock. That would however require the cylinders to be filled with water/anti-freeze. What's the longest you've run it?
Check codes and check spark at the coil when it goes to a no start condition. ICM and/or coil could be getting hot and causing a no start.
Ive had the car running for about 20 minutes or more. It doesn't shut off on its own.
Old Jun 16, 2014 | 12:15 AM
coil can do that, see if your parts store can test it. call unless your already going by
Old Jun 16, 2014 | 11:53 AM
MKCoconuts's Avatar
Most part stores can test the ICM. That will at least narrow that down. If it comes back good or bad, space it away from the head with a few washers (you may need longer bolts too) to keep the heat soak down.
Old Jun 18, 2014 | 09:22 AM
Now when your talking about the icm do you mean the ignition control module or the ignition coil interface module because theres a big difference in price between the two.
93 1993 Chevrolet Camaro Ignition Coil Interface Module - Engine Electrical - MSD - PartsGeek
93 1993 Chevrolet Camaro Ignition Control Module - Engine Electrical - MSD - PartsGeek
Old Jun 18, 2014 | 10:44 AM
Those are the wrong parts, you want the ignition control module for the 5.7 V8, the stuff you are looking at is for a 3.4 V6 with DIS
Old Jun 19, 2014 | 12:29 AM
Old Jul 5, 2014 | 08:15 PM
greenmachine96's Avatar
Wait so when it wont start does it turn over at normal speed or does it turn over than normal?
TheArtfulLodger
May 4, 2013 07:06 PM
wes232323
Aug 23, 2010 08:53 AM
randyorton
Jul 22, 2010 01:06 PM
92lxsleeper
Aug 27, 2008 12:29 PM
jmreaper
Jul 30, 2008 02:03 AM
