02 sensor lean code why???
yea its the key on engine off thats got me wondering it jumps to 45 psi pump running then drops to about 38-39psi off and holds.Ill double check with another gauge 2-3psi isnt much but its got me frustrated at this point.
Just went and got a fitting for my gauge. 41psi key on engine off holds firm. 37psi at idle. Def has a little more power. Still has a slight miss under 2000rpm. Is it possible that running lean the fd up the plugs?
HOW did you get that rt O2 out?!?
With a wrench. I think it was 7/8 might of been 13/16. Took longer to jack it up and get under it then anything else. I use antiseize when i put things together makes life easy when u take it apart...
its a 7/8. anyway so still no lean code?
When I tried from under car, I could get a socket on, but nomatter what extensions or angles I used and removing the starter and PB blaster, she wouldnt budge...
Did you use an O2 wrench?
Im a big fan of antiseize; with the PO had been...
loaks u need heat. Try to get ahold of a acetylene torch. If you get it hot enough with some good gloves you should literally beable to get it out with your fingers. If u get stuck start a new thread the guys on here are very helpful! And yes the damn ses came back for right 02 lean. It will only come on after a long time at idle. Im gonna drop the exhaust and re torque the flanges maybe its suckin air...If that doesnt do i dont have a freakin clue.
