LT1/LT4 Tech 1993-1997
**MODS Done Yourself**
Old May 26, 2009 | 10:18 AM
retroj23Z28's Avatar
Default **MODS Done Yourself**
I wana mod my cam and I would like to start with ignition/fuel/exhaust so I need to know how hard is it to change the plugs and wires in a lt1 cam? Is it better to go from the top or get it on a lift and go from the bottem? Also I want to upgrade to MSD but HOW HARD IS IT TO CHange the optispark?? Is it hard to unbolt and set the timing on it??
Old May 26, 2009 | 10:40 AM
SSV6's Avatar
Have fun. Plugs are easier from the bottom. I suggest ACDelco Rapidfire plugs.
Old May 26, 2009 | 11:48 AM
95slvrZ28's Avatar
Correction: some of the plugs are easier from the bottom.
Don't change the opti unless you have to, it's not a simple job because the Opti is pretty hard to access. The MSD isn't going to get you any performance increase anyway, especially on an otherwise stock or bolt-on car.
Old May 26, 2009 | 12:00 PM
z28rob18's Avatar
what he said. there's 2 plugs that are real hard to get from the top #5 and #6 those are the 2 that i havent been able to get from the top. it may help to hav a friend to give you a hand
Old May 26, 2009 | 12:03 PM
SSV6's Avatar
My bad, never fooled with an LT1, just talking from experience with my old 3.8 and horror stories from my friends.
Old May 26, 2009 | 12:04 PM
SpecterGT260's Avatar
Ninja Administrator
agreed. leave the ignition alone untilyou HAVE to swap it. do LT headers make the plug swap easier for u guys like they do for the ls1? if so i would recommend it lol. the ls1 plugs were such a pain id pay the 1 time 500 bucks to never have to do it again
Old May 26, 2009 | 12:37 PM
95slvrZ28's Avatar
Headers made some of mine easier and some of them harder. The primaries of my headers run almost exactly over the top of some of my plugs so I can't get a regular plug wrench on them.
Old May 26, 2009 | 12:48 PM
lt4weeda's Avatar
I would say it made it easier to change. Not so much removing the plug, but just being able to see the plugs
Old May 26, 2009 | 10:23 PM
torque_is_good's Avatar
LT headers FTW on the LT1. THe plugs that you can't use a ratchet, simply put the socket on the plug and use an open end wrench. I can change the plugs on the passenger side in about 15 minutes now (after it's on the ramps) as opposed to hours before.
Old Jun 9, 2009 | 12:41 PM
Thanks for your replies, hopefully i'll get my LT1 dialed in soon, then it's time for paint..
