LS Series Tech 1998-2002
What size intake?
Old Oct 25, 2007 | 04:22 PM
sk8rax350's Avatar
Default What size intake?
What size (mm)intake, TB, etc.is best for running naturally aspirated?
Old Oct 25, 2007 | 04:24 PM
SpecterGT260's Avatar
Ninja Administrator
Default RE: What size intake?
unless u are going crazy, most guys just port the stock tb. you will want to buy an ls6 intake manifold at some point.
Old Oct 26, 2007 | 01:36 AM
95slvrZ28's Avatar
With fuel injection you can go as big as you want, but the bigger you go the slower your throttle response will be. The biggest most people go with a car that is running the street is 90mm, but if you do that you'll need an intake manifold to accommodate for it. You won't really need any more flow than the stock one until you're making some good numbers (probably 400+ RWHP).
Old Oct 26, 2007 | 06:34 AM
sk8rax350's Avatar
How much better is a Fast intake than the LS6? It's kinda pricey and I've heard nothing but good about both. Should I just get an LS6 one until I actually start making some hp?
Old Oct 26, 2007 | 08:02 AM
Ninja Administrator
the FAST is better for a couple reasons. better flow and cooler intake temps. However, not worth the extra money unless you intend on doing some other big mods. the ls6 will suffice. I cant tell u exactly how much hp the ls6 intake can support, but its plenty. for example, full exhaust, rear w/ gears, a big cam, and a 150 shot was all it took for a guy I know to run 10.50's at the track. this through an ls6 intake. if u dont plan on going too much faster than this save ur money.
Old Oct 26, 2007 | 09:44 AM
JD1969's Avatar
I am at 393 rwhp with a LS6 and stock heads. IMO untill you get better flowing heads you don't need the FAST intake.
Old Oct 26, 2007 | 03:01 PM
sk8rax350's Avatar
LS6 it is! Thanks guys!
crimson09
Dec 15, 2018 07:07 AM
carid
Vendor Special Buys
Jan 20, 2015 07:08 AM
microkid
Dec 20, 2010 08:59 PM
longarmperrin
Dec 17, 2010 08:49 PM
