Transmission Problem...... HELP ME
hey.
i got a problem with my automatic transmission in my camaro ls1. it ****s 1 to 2 perfectly, but when its in 3rd gear is goes to neutral, even if done manually or using the OD. please help. ASAP
A- 1-2 accumolator spring missing..probably not concern
B- 2-3 accumalator spring missing..probably not concern
C- forward sprag falling apart.....#1 GM 4l60 problem
D- due to foward sprag falling apart, over run clutches burnt. and most probably 3rd clutches burnt.\
vehicles with 10,000 miles do this. not the drivers fault those sprags suck
