Removal of back seats
the top part that pull down has 2 bolts in the bottom that are a star * shaped head, couldnt tell you what size. The bases are fasten with one bolt in a the front middle, its like a 13mm or 1/2" or something.
Its pretty trick to get to the star bolts it you dont wanna take the panels out just try getting just the star key bit in the bolt and use a spanner to turn it (assuming you have one of these tool sets where the ends are a hex shape, if you understand what i mean)
