LS Series Tech 1998-2002
Rear end question, help please =]
Old May 6, 2011 | 01:46 PM
SpecterGT260's Avatar
Ninja Administrator
u can go that route, but eventually you will have dropped enough money on new rear ends to have just bought a 9"
Old May 7, 2011 | 07:06 PM
DarkKnight's Avatar
GTO Killer
LimeKnight
prolly looking towards an ms3 now and closer to 400rwhp
Old May 7, 2011 | 08:46 PM
Ninja Administrator
From what I understand, the rear housing flexes which causes the gears to meet at at off angle. Upgrading gears amplifies this. Rear diff cover is th only bandaid fix
Old May 8, 2011 | 09:24 AM
DarkKnight's Avatar
GTO Killer
LimeKnight
hmmm, yeah idk, i know some people running 500 with stock rear end without a problem and then i know 2 guys right around 400 who blew their rears... ugh
Old May 8, 2011 | 09:35 AM
Ninja Administrator
"without a problem" means rolling starts and glamour driving.
Do you want to race it, or have a 16 second 500hp car? Just because someone HAS run it without blowing it up doesnt mean that is at all a good idea. Plenty of guys have also banged hookers raw dog without contracting AIDS. Do you want AIDS? no... so get a rear end
Old May 8, 2011 | 11:44 AM
Buffalo02Z28's Avatar
LOL, Spector, that was an awesome analogy.
Old May 8, 2011 | 02:21 PM
cbr600rx7's Avatar
12 bolt or 9 inch take your pick. I would go 9 and be done with it since it will take any thing you can throw at it. Building a 10 bolt is a waste of time and money end of story.
Old May 10, 2011 | 02:45 AM
maudyZ28's Avatar
my 2 cents, grab a spare 10 bolt so you've always got a spare axle to hand. If your building the motor first the ms3 cam etc is not going to be as bad as a 500 hp turbo car on the rear. Manuals put more strain on the rear too when the clutch is dropped espectially with tall gears 3.73 up as the pinion is really small, thus weaker.
if you want the power first build the motor and get spare 10 bolt but drive carefully, and keep saving for the 9"
Old Jun 7, 2011 | 04:44 PM
Cam02ss's Avatar
Dark, if you plan on hooking at all...plan on buying alot of rears. I blew my 10 bolt apart with a girdle, went to a Strange 12 bolt, broke that too. If you don't plan on selling your car, buy a 9" and be done with it. Midwest makes a great FAB9, along with some other companies.
Old Jun 8, 2011 | 09:20 AM
  #20
Cheeks's Avatar
August 2011 ROTM
go with the 9 inch for sure. You won't be dissapointed.
The 9 inch housings don't have to be fabricated, but they do need cut down and you need to weld the GM ends on them. First Try Engineering did mine, I think he's doing them for around 1500-1700 now. I've had mine under the car for a year now, its held up to countless launches and 60ft times in the 1.4x range.
we started with this: a 79 ford f150 9 inch
then a couple of days of hard work later, had this:
the lightning bolt on the back is because they call my car "white lightning"
