LS Series Tech 1998-2002
Questions about intake/throttle body swap
Old Feb 1, 2010 | 03:44 PM
reines200's Avatar
Default Questions about intake/throttle body swap
I have a 98 z28 that I'm going to swap out the stock LS1 intake and throttle body with a weiand intake and 80mm bbk throttle body. Is it just a simple bolt on swap if I don't have the EGR system? The throttle body will also connect right up without any modifications, correct?
Old Feb 2, 2010 | 05:14 AM
maudyZ28's Avatar
how much are you spending?? the weiand is ony as good as the stock GM LS6 version, so that might be cheaper, unless you plan to port a lot, or add nos??
it should bolt up but there may be an issue with the coolant lines the early ls1 run under the manifolds crossing each head. You can get back block off and a front crossover tube if you want to.
Fishy99SS
LS Series Tech
Apr 1, 2013 01:40 AM
Jchapa
Apr 1, 2011 05:19 AM
DC1Camaro
Jun 29, 2010 04:23 AM
andersonSLPZ28
Jul 9, 2009 09:47 AM
