ported 241 heads on 5.3 block
Not worth it unless you are boosting it. The 241 heads flow better than the stock 5.3 heads however its going to drop your compression A LOT. The 241 heads have 66ish cc chambers compared to 61 on the LM7. I am not going to do the math on it right now but its going to drop you probably below 9.0 CR. This would be great if you planed on pushing 18 pounds of boost into it but its going to hurt you other wise.
