ported heads
Old Nov 10, 2008 | 10:07 PM
Chuy3.8's Avatar
From: Eagle Pass Tx. , South Padre Tx, And San Antonio tx.
Default ported heads
does anyone know how much hp i can gain by porting out the heads?
Old Nov 11, 2008 | 07:49 AM
02StanGT's Avatar
Default RE: ported heads
Depends on how ported they are, what kind of cam, what kind of intake/exhaust setup you have.
Old Nov 11, 2008 | 08:40 AM
SpecterGT260's Avatar
Ninja Administrator
you cant expect to gain anything if the rest of the motor isnt built to handle the extra flow. you will need full boltons and a good NA cam before you should consider a head port
Old Nov 11, 2008 | 12:52 PM
Chuy3.8's Avatar
xp hot cam, i have some custom dual cold air intake (i saw it at O'reilys) , dual exhaust , pacesetter headers , valve springs , Diamond racingForged pistons Kit ,posi system , v8 rear end and 75 shot of Nitrous oxide .
Old Nov 11, 2008 | 05:39 PM
Ninja Administrator
you could probably net a good amount of power then from a good port job. it may be in your best interest to find some place that trades your stock heads as cores and gives you refurbished ported ones at a cheaper cost.
98camarov6
LS Series Tech
Aug 4, 2013 12:50 AM
94N4CER
Feb 3, 2009 03:14 PM
JimMayor007
Oct 1, 2007 11:04 AM
