LS Series Tech 1998-2002
O2 simulators
Old Jan 28, 2009 | 03:52 AM
maudyZ28's Avatar
Default O2 simulators
do any of you people with de-cats/gutted cats use oxygen simulator sensors or just plug sensors back into the exhaust ??
Old Jan 28, 2009 | 07:50 AM
You always need the upstream O2 sensors. If you have a OBDII car with both upstream & downstream sensors and you do away with the cats, the downstream sensors will complain that the cat is not working. You can use the O2 sims in place of the downstream sensors to send a fake signal to the PCM, or you can tune out the downstream sensor feature from the PCM.
Old Jan 30, 2009 | 04:50 AM
maudyZ28's Avatar
thanks, thats what i was going to do with the downstream ones, however does this make the car run fine or is it better to tune it out??
Old Jan 30, 2009 | 06:54 AM
Makes no difference on how the car runs, the idea is to keep the check engine lite off.
My01Z28
Jun 26, 2007 10:07 PM
red 1
Apr 20, 2007 08:37 PM
