LS Series Tech 1998-2002
LS1 cam question
Old Dec 8, 2012 | 01:31 PM
Z28Camaro98's Avatar
Default LS1 cam question
Hi there. Could someone help me understand what different cams do? I hear engines on youtube with big cams in them and they have a lope to the idle. How are they installed? How much money and what does it do. I just would like to learn a little bit. Im thinking about possibly doing a few mods to my 98' LS1 and just need some info. thanks!
Old Dec 8, 2012 | 06:48 PM
Failed Devices's Avatar
Definitely start with some bolt on mods before doing H/C/I work, boltons pay off even more when you look to cam it later.
In terms of learning about cams, their functions and what all those numbers mean:
*** Cam Guide *** - LS1TECH
And here is a good install writeup to give you an idea of what is involved:
LS1Howto.com
The actual cam itself is relatively cheap, usually only a couple hundred bucks, but its the supporting mods that end up bumping up the total cost.
JPrice
May 20, 2012 03:48 PM
endo
Sep 30, 2010 12:51 AM
josh75camaro
Jan 7, 2010 09:09 PM
