LS Series Tech 1998-2002
how many psi to much
Old 04-28-2007 | 09:14 PM
bjames102's Avatar
Default how many psi to much
i have a vortech V9 superchargerwich is inmy 98 SS Camaro,how much PSi is it safe to run with?the kit only puts out four PSi[says 5to8]i don't want blow my motor up but want toget respect at track.
Old 04-28-2007 | 10:02 PM
Saint_Ali's Avatar
Default RE: how many psi to much
you should sell the supercharger and get better heads and a good cam
Old 04-29-2007 | 04:53 PM
Lee Willis's Avatar
Before you sell the SCr try a smaller pulley on it. 4 lbs is probably only adding 15-20 HP. It takes 5 -6 to make a difference and about 7 is as much as you should run with a stock bottom end. That ought to give you about 100 RWHP more than stock. Also have the ECM tuned, well, by a pro.
