LS Series Tech 1998-2002
Hey guys...maybe you can help
Old Mar 15, 2010 | 03:55 PM
allamericanz28's Avatar
Default Hey guys...maybe you can help
Hey guys pretty new here but I got a questions maybe you can help me with.
Well long story short I brought my car down to the dealership to get the oil pressure sending unit fixed. They told me that my power steering pump was leaking a bit(maybe relevent). Well I get it home and drive it to work (about 15 miles on the highway) and after I got there noticed it was smoking. I noticed it before I brought it but was deff not as bad. Quite a bit acctually from what looked like the back part of the engine. It was a white smoke with no smell really.
Could it be power steering fluid leaking and burning? Or some other oil related problem?
Old Mar 15, 2010 | 05:20 PM
Y2K's Avatar
Y2K
It's pretty hard to say,could be a lot of things.
Might just be residual from the job done but could also be a problem.
I'd gunk the engine clean and look for any leaking fluids,if it gets worse instead of better there must be a problem.
Put some newspaper or card board under the car and let it idle for a while to see if anything is dripping off the engine.
Old Mar 29, 2010 | 05:23 PM
InjectorsPlus's Avatar
If that doesn't work you could be looking at a head gasket.
Old Apr 3, 2010 | 05:45 PM
adamcc91's Avatar
usually when you find white smoke it is a headgasket / coolent problem
iLL95
Sep 27, 2011 09:08 AM
97Maroman
Jun 26, 2010 11:03 AM
Mtowles
Mar 21, 2010 05:09 PM
z28rob18
General Racing/Tech
Nov 22, 2008 03:23 PM
